carb
GK
11-06-2005 17:53:14
I rebuilt a carb on a D15 seriesII, and now, when I crank the engine gas leaks from the choke, when it never happened before. Does anyone have a suggestion?
old
11-06-2005 19:05:25
 Re: carb in reply to GK, 11-06-2005 17:53:14
One of 2 things come to mind. Either you didn' get the seat tight enough or the new rubber tiped needle isn't seating as it should be. Open it back up and pull the float. Drop the needle back in the seat and then tap on it a couple times with a small hammer etc. One other thing you may not have the float level set right.
