ele start
olie
11-06-2005 16:55:26
Does a 1939 wc have ele start and a genartor Thanks OLIE!!!
cbp
11-06-2005 17:40:32
 Re: ele start in reply to olie, 11-06-2005 16:55:26
I had a 39 (probably) and it did but that doesn't prove anything because we had to date it based on the engine and that just as easily could have been wrong. The transmission case was replaced and not restamped. The starter was for sure available on a 40. The C also had lights/starter when it came out in 40.
chalmersbob
11-06-2005 17:27:08
yes it can. mine does, but that doesn't mean all of them will. bob
cbp
11-06-2005 17:44:25
 Re: ele start in reply to chalmersbob, 11-06-2005 17:27:08
Do you think the C was ever offered without a starter? I always wondered that. The part manual says so but I've never seen one crank only.
Eldon (WA)
11-06-2005 19:15:16
 Re: ele start in reply to cbp, 11-06-2005 17:44:25
I have a C with the factory plug still in the starter hole and the factory insert still in the tool box area that is cutout for the battery. No generator, lights or wiring harness.
cbp
11-06-2005 19:35:35
 Re: ele start in reply to Eldon (WA) , 11-06-2005 19:15:16
That IS impressive. Is there a picture on the tractorshed????
Eldon (WA)
11-07-2005 21:36:59
 Re: ele start in reply to cbp, 11-06-2005 19:35:35
third party image
Here's the toolbox insert.....nevermind the weed that looks like a line.
cbp
11-08-2005 17:26:04
 Re: ele start in reply to Eldon (WA) , 11-07-2005 21:36:59
I think you've got one amazing C. I wouldn't let go of that for anything. Single tricycle and no electrics. Have you ever thought that you may have the only one left. I've never seen one.
Eldon (WA)
11-07-2005 21:30:03
third party image
Here's a pic of the factory plug.
Eldon (WA)
11-06-2005 19:45:49
I'll try to post a pic tomorrow.
cbp
11-06-2005 20:34:05
 Re: ele start in reply to Eldon (WA) , 11-06-2005 19:45:49
Thanks, I've had 2 Cs 5 Bs and an IB and really loved them. I had to part with most but the unusual ones are the ones that stick in your memory. Your C must fall into that category. On the first C I restored, I even had the 2-way up and down plows, and actually used them to do the garden one year instead of my dual 16s on the D-14.
Eldon (WA)
11-06-2005 20:38:18
 Re: ele start in reply to cbp, 11-06-2005 20:34:05
This one has a single front wheel and also has the heavy cast rear wheel centers that have the 4 cut-outs so it originally had rear steel!
