190 xt bigger turbo and pump
es
11-06-2005 14:40:22
like to get one for tractor pulling i was told 3lm turbo and 450 roosa master pump realy wakes them up are this parts off the shelf and would i have to make any modifictions and how mutch HP would it make thanks
danweinert
11-08-2005 18:56:31
 Re: 190 xt bigger turbo and pump in reply to es, 11-06-2005 14:40:22
I'd reconsider using a 190xt for a pulling tractor. They have rearend issues. I have two and I have my share of problems with them. The rearends on them originally came from the D19. They just put bigger axles in them. My local tractor junk yard has at least 20 190xt's all of them with bad rearends.
ANON
11-06-2005 16:21:33
Bigger pump sure does help. Higher volume lines and lazered out injector tips helped too. You can keep the stock turbo and it will work. Have the head worked on with bigger valves and some porting. The bigger turbo won't fit under the hood unless you make a tapered shim to tilt it in. You can pull in third gear on most tracks. Someone out there has a faster third gear to bring you up to around 10 MPH. Cost: about $4000.
