WD/WD45 wide front, strength?
Rock_Picker
11-06-2005 13:38:53
Been wantin' a WF for my WD, but am concerned about how strong they are. If a wheel drops in a ground hog hold or something similar, is the spindle/axle likely to break? (assuming a reasonable speed for the tractor). I also hear of "3-bolt" and "4-bolt" wide front ends. Would someone please explain the difference? Thanks..... .....RP
L E G
11-07-2005 21:45:40
 Re: WD/WD45 wide front, strength? in reply to Rock_Picker, 11-06-2005 13:38:53
I have used both and never had a problem. I guess if you are very unlucky or crazy maybe.
I have an A/C original wide front and an A/C original power steering for sale. Call 937.307.5441.
Texas Denny
11-06-2005 20:19:33
My wide front is the three bolt. I got the tractor with a loader. The previous owner had trouble and tried to weld the plate to the casting which didn't work. I pulled it apart and put helicoils in two of the holes and have had no trouble since then. I wouldn't worry about the spindles. If you don't abuse it, the wide front should last as long as the rest of the tractor.
Eldon (WA )
11-06-2005 19:08:42
I've got 5 three bolt wide fronts and all but one have been beefed up in that area. The problem is the bolts are too close together and you have a ton of leverage when a wheel hits a hole, tree stump or rock. I've never seen a 4 bolt bracket that failed the way the 3 bolts do, but I have seen some pretty bowed axles on loader tractors. I've got one with welded up radius rods that looks like it had a loader on it.
mace56
11-06-2005 17:36:28
Actually some of the worse damaged tractors I have seen have been narrow front tractors that dropped into a hole when mowing or brush hogging in tall weeds. Sometimes big castings up high break instead of the front end so it gets expensive.
Seems like with wide front you would have at least half a chance to save the tractor, even if at cost of one side's spindle.
mace56
11-06-2005 17:35:17
bw in mo
11-06-2005 17:17:58
Run them for years never had any trouble until put loader on it then it spread out , didn't break any thing at any time. 3 bolt & 4 bolt , the most front plate that the axle pivits on will have either 3 or4 bolts in it.
wdtom
11-06-2005 17:17:21
I don't think you would break any axle parts with normal use and care for what you do to it. they are pretty strong. You can break anything if you try hard enough. As for 3 and 4 bolt, it goes like this. There is a steel plate bolted to the front of the steering box that supports the axle, early ones had 3 capscrews, later ones had 4. I hear, but don't know if it is true, that if you are doing heavy loader work or some such that stresses the front end you want 4 bolt. Must have been a reason they changed, or they would all be 3 bolt. For normal work I wouldn't worry about a wide front end, or whether it was 3 or 4 bolts.
matt lansing
11-06-2005 14:28:21
I have one that had a wide front and it was great. You might have to add a power steering unit. I have a shwartz wide front that fits on a WD-45 for sale if you wnat mroe info email me.
Matt lansing
[email protected]
