bad oild filters from AGCO?
Jpuleo
11-06-2005 09:38:29
I just went to change the oil in my wd. nasty sludge. Oil pressure read fine though. I put on a new Allis Chalmers logo Agco filter #70240912v. There was verry low pressure. Messed around a little then tried a Hastings filter I had left over from when I had my B. Oil pressure was perfect. Have others had problems with agco filters?
Aaron SEIA
11-06-2005 10:04:56
 Re: bad oild filters from AGCO? in reply to Jpuleo, 11-06-2005 09:38:29
Any oil filter that has a paper element on the W series engines is going to cause very low oil pressure. Just read something that said the AGCO filters have been using the paper type. There is a new WIX number that uses the old cotton filter media, 57011. Should fix your pressure problem.
Aaron SEIA
steve(ill)
11-06-2005 18:16:00
 Re: bad oild filters from AGCO? in reply to Aaron SEIA, 11-06-2005 10:04:56
yes, the old AGCOo andn WIX filters are crap. the newere AGCO filters are becoming available now. Make sure the get the stuffed cotton design like the B filter you had.--- or just forget it and stick with Hastings and Baldwin T300M or FRAM 159. those work good.
