CA worth
BruceR TN
11-05-2005 15:54:29
Can someone give me a ballpark figure on the worth of a '51-'53 CA? Tricycle gear, runs great, sheet metal good, but needs foot clutch (will still pull light load). Comes with rear wheel weights, cultivator, two row corn planter, bottom plow, drag (tobacco) setter, and a sickle bar mower. Any help appreciated!
Eldon (WA)
11-05-2005 18:25:22
 Re: CA worth in reply to BruceR TN, 11-05-2005 15:54:29
Is the hand clutch lever there and does it work? It may be slipping thru it also. Some had the handle removed and plates bolted together because of this problem, but it eliminates the "live" hydraulic and pto and makes the tractor less valuable.
If the hand clutch is operable, tires and rims good, and all the implements are in good shape (and mower, plow and planter are AC), I'd go as high as $2500. You have a lot a variables to deal with.
BruceR TN
11-06-2005 14:22:54
 Re: CA worth in reply to Eldon (WA), 11-05-2005 18:25:22
Thanks, thats what I needed, just an idea of worth. We'll see what the market will bear.
