Piston vs Gear Pump Hydraulics
jeffalex2
11-05-2005 03:59:13
It's normal for piston pumps to produce vibration in the hydraulics as opposed to the smooth action you get from gear pumps, right?
cbp
11-05-2005 04:57:32
 Re: Piston vs Gear Pump Hydraulics in reply to jeffalex2, 11-05-2005 03:59:13
There is certainly a difference in the smoothness just in thinking of my AC Backhoe feed vs my B 3-point. The B pump was rebuilt a few years back and it does still tend to vibrate it's way up a bit unlike the 816 though it's more the noise than serious vibration. The 816 can move quite smoothly in it's response to the stick and of course there is no sensation of the pump working beyond engine RPM as it comes under heavy load. But you shouldn't have excessive vibration as that indicates something is wrong.
Before I rebuilt the B pump it was very jerky and would leak down pretty quickly. The balls weren't seating well and it wasn't smooth because one of the pistons was doing more work than the other. I was able to get a couple of external parts from agco (like the linkage return spring) but on the internals, I just cleaned up the seats so the balls would seal against them. I think replacements were even available but I just did it my way instead.
I also had a C piston pump (identical to the B) where one of the springs broke and that created the same symptoms only radical, it would bounce it's way up and immediately come down. It was an easy fix even though it scored the cylinder a bit. Agco still had the springs at that time. It was about 12 years ago.
