Sticky Clutch
jeffalex2
11-05-2005 03:51:39
Can you use brake cleaner or anything else to hose down the clutch plate to help stop sticking?
BCnT
11-05-2005 08:45:33
 Re: Sticky Clutch in reply to jeffalex2, 11-05-2005 03:51:39
they stick on the input shaft...surface rust keeps plate from sliding...if you can get to shaft put a TINY bit of grease right behind clutch disc...my ford does it in damp weather...hasnt gotten to be enuff of a pain to split tractor YET
Texas Denny
11-05-2005 16:40:05
 Re: Sticky Clutch in reply to BCnT, 11-05-2005 08:45:33
BCnT, I've got an 8N that has plagued me since I got it. I split it about 4 years ago. I took off all the sharp edges on the spline of the input shaft and the clutch disk. I polished these surfaces as best I could. Then I lubricated the shaft a little (oil) and put it back together. Within a month, it was sticking like old times. I contacted Ford. They claimed that they never heard of such a thing. But they absolutely recommended zero lubrication because the clutch dust mixes with the lub and makes a sticky mess. So I broke the tractor a second time and cleaned everything per their recommendation. A couple of months later, it started sticking again but not nearly as bad. I've used it since then but won't let anyone drive it. Six months ago, I bought a used clutch disk. I'm going to replace my new clutch with it.
Weird!
BCnT
11-05-2005 16:51:08
 Re: Sticky Clutch in reply to Texas Denny, 11-05-2005 16:40:05
numero uno standard reply we were taught in fomoco school...dont admit NUTHIN!
i used a graphite based grease on this '62 2000...it lasted awhile but its back to stickin again...that enclosed bellhousing just breeds moisture...i've considered drilling air holes all the way around so it'll air out but i got a '59 ford 3/4 ton and it sticks too...best cure is use em all the time.
cbp
11-06-2005 03:54:48
 Re: Sticky Clutch (and OT question for Texas Denny in reply to BCnT, 11-05-2005 16:51:08
Agreed on use. I've only had one tractor stick, a Farmall Super C, got it home, got it running and took off fine only to find it didn't want to stop and the load kept it from wanting to come out of gear. That's one of those adrenelin moments, but dropping the throttle let me pop it out easily. After the second or third use, it never did it again.
Texas Denny, brief OT question here if you are a fomoco factory mechanic. Are the injectors on a 92 F350 EFI 360 something an old tractor mechanic should take on. I ran mine out of gas to the water and gunk at the bottom of one of the tanks, It's run horribly ever since. Cleaned out the fuel supply up to and including the filter but it appears I must have clogged the injectors. Dealer-only or Shadetree work??? I've been avoiding it for a couple of months.
Texas Denny
11-05-2005 19:45:07
 Re: Sticky Clutch in reply to BCnT, 11-05-2005 16:51:08
That use thing is accurate. I only use this tractor about 3 times a year for mowing. Getting that clutch loose the first time is the worst. It does improve dramatically after the first break loose
test
11-17-2005 20:07:37
 Re: Sticky Clutch in reply to Texas Denny, 11-05-2005 19:45:07
test3
Doug in IL
11-17-2005 20:10:11
 Re: Sticky Clutch in reply to test, 11-17-2005 20:07:37
test 4
