Well I Guess
Dick L
11-03-2005 13:02:30
I won"t whip over and help you tonight with me being in the North West Corner of Ohio.
Take a look at the drawing and make sure you have all the parts back in the carburetor as shown.
It could act like that if you forgot some parts, or you are firing number one plug on the exhaust stroke rather than the compression stroke. If as you say it has compression, the spark is at TDC at number one cylinder with both valves closed which would make it on the compression stroke, and the plugs have signs of fuel, it should run.
TDC will show in the inspection hole two times as the distributor makes one complete revolution. Common problem with people is to be one revolution off on the crankshaft and the roter pointing at number three when it should be pointing at number one.
third party image
w.h. king
11-03-2005 18:02:22
 ca will not start in reply to Dick L, 11-03-2005 13:02:30
HOW CLOSE ARE YOU TO MOCKSVILLE NC? I CAN FIX THAT TRACTOR!
