mashed oil line
mace56
11-02-2005 19:22:35
The small oil line from oil filter head to timing gears on my B appears to be kinked near the rear bend. No sure if oil is getting thru. If I start with the front loose should I see oil running out of the line? Guess those lines would have to come from AGCO if I need a new one?
BCnT
11-03-2005 08:07:39
 Re: mashed oil line in reply to mace56, 11-02-2005 19:22:35
you should be able to make your own out of copper tubing...copper will hold oil pressure...no problem
cbp
11-03-2005 04:17:11
Have seen where people have spliced in very small oil hose section such as that used on motorcycle oil lines. It's ID should be tight to the OD of the oil line. I wouldn't use heavy clamps on it nor run too long a section of the larger ID hose. I've seen it in on a working machine in as long as a 5 inch section. About 8 years ago I was able to get a new OEM one from an Agco dealer in Western WA. Not sure if that was a long leftover fluke or what.
