WD45 hand crank shaft
Bill Graham
11-01-2005 16:42:50
I want to remove the hand crack shaft used to start the tractor by hand. The shaft has pins through it on each end. Are they tapered pins that can be removed to pull the shaft out? If they cannot be removed how does one remove the shaft?
JMS/MN
11-01-2005 22:05:16
 Re: WD45 hand crank shaft in reply to Bill Graham, 11-01-2005 16:42:50
They are straight pins- just knock them out with a hammer and punch,about 1/4 inch dia.
