rebuild
Tim McMullen
11-01-2005 15:28:04
I have a 1938 Model B Allis chalmers tractor and it has almost all origanl parts and now doesnt run very good. I am thinking about rebuilding it and was wandering about the price range of an estimated cost. I wont be albe to work on it for several months because i am in Iraq right now and am getting home in March but i was wandering if i could get info on it right now so i can start raising money to fix it. Also could you tell me how much brand new tires for it would cost?
Thanks Tim McMullen
jeffalex2
11-02-2005 04:55:50
 Re: rebuild in reply to Tim McMullen, 11-01-2005 15:28:04
If it is just rough and doesn't smoke too much (like mine was), you can get away with rebuilt mag ($200), rebuild the carb ($25), new brakes ($80), change all the fuilds and filter ($75).
Enigine rebuilds run between $600 and $1000 depending what you run into (oil pump, water pump, head work, gaskets, etc)
My rear tires were $175ea, and my fronts were $40ea.
THANKS FOR YOUR SERVICE!!
cbp
11-01-2005 18:24:29
It looks like the basic rebuild kit is about 300 depending on what you want (pistons, sleeves rings). Just looked in the rebuild kit link above. I didn't check, but I'll bet you'll up the bore in the process. I had a 38 at one time. Pretty cool, no hydraulics, no battery, starter etc. That was one of my favorites and the only thing non-original was trans-am bucket seat ;-).
