A/C model B
pilot199
10-31-2005 08:02:00
I'm looking for more info about installing a 3 pt. hitch on my '39 model B.
What I want to do is use it to lift & run a belly mower (4' - 5'). The present belly mower is small & ancient with a hand lift lever.
Anyone know how I can best accomplish this. Also, who makes a quality belly mower??
Thanks,
Gary
Baton Rouge
CHALMERSBOB
10-31-2005 17:13:08
 Re: A/C model B in reply to pilot199, 10-31-2005 08:02:00
YOU CAN LIFT A BELLY MOWER WITHOUT A 3 PT. WOODS MOWERS COME WITH BRACKETS TO USE PRESENT HYDRAULIC CYLINDER. BOB
farmerwannabe
10-31-2005 12:09:40
Pilot199, I have a 3 pt. on my 1941 B and it comes in handy, however if I didn't have it I think I would go ahead and get a pull behind mower from the local TSC. I've seen 'em in action and they're pretty slick.
ed brown
11-02-2005 15:24:54
 Re: A/C model B in reply to farmerwannabe, 10-31-2005 12:09:40
I just bought a 1939 B A/C It only has a hand crank, is there a safe way to crank it so as not to get a broken arm? Any info will be appreciated.
Regards, Ed 1-(269)367-4837 home
or email answer if possible
farmerwannabe
10-31-2005 12:09:32
farmerwannabe
10-31-2005 12:09:26
Stan(PA)
10-31-2005 08:17:55
Woods makes a good belly mower, but they ain"t cheap! You might get a used one for $500 or $600, but make sure it came off a B. The mounting brackets are different for each tractor. What"s wrong with using the hand lift? I have a 5 foot deck on my Farmall A, and with a spring assist, it lifts pretty easy. If you just want 3 point for lifting a belly mower, I would save the money and stick with the hand lift. Just my opinion ....Stan
