Allis Chalmers C oil pump
T Davis
10-31-2005 04:42:58
how do we figger out what bump to get and were is it located ?
Dick L
10-31-2005 06:41:05
 Re: Allis Chalmers C oil pump in reply to T Davis, 10-31-2005 04:42:58
The oil pump is located at the rear right hand side of the engine just above the flywheel. You can see the pipe that screws into the pump just behind the oil filter. What are you trying to figure out about the oil pump. The B"s, C"s, and CA"s have the same oil pump. Should be easy to find, new or used, unless you are trying to do something different than just feed the usual C bearings. Now if you are meaning the hydraulic oil pump it is mounted on the power take off assembly, and they are easy to come by used. Rebuild kits are available for them.
