Loose rim on B
mace56
10-29-2005 15:57:03
My right side rim on the B that is loose.
One eccentric is already tight as it goes, I adjected the other cam bolt full out as well. I still see a gap.
I see two solutions posted previously. One Used a shim sheet to tighten the cam more. The other removed the vee clamps and built up with weld.
I assume it is normal to only have two eccentric bolts. Should I leave the non-adjust clamps alone and just work with the two eccentric clamps?
Thanks in advance for any good tips.
I pulled the cultivators off today so I can work on the rims a lot easier.
Dick L
10-29-2005 16:22:27
 Re: Loose rim on B in reply to mace56, 10-29-2005 15:57:03
One of my B"S has all four eccentric clamps.
Texas Denny
10-30-2005 08:54:23
 Re: Loose rim on B in reply to Dick L, 10-29-2005 16:22:27
I would do the building up on the stationary ones. Then, you don't need to worry about the finish.
steve(ill)
10-29-2005 18:27:33
both my B have the stationary clamps built up 1/8 inch so the cams can do their work. weld a few beads length wise and touch up with a body grinder.
