D17 CARB
D17JIM
10-29-2005 04:39:46
I AM MAKING PROGRESS ON MY RECENT PURCHASE. MY D17, PUT SOME MARVEL OIL, ATF AND BRAKE FLUID IN AND RAN IT. AFTER LEAVING THE SHOP AND TELLING MY WIFE AND NEIGHBOR NOT TO CALL THE LOCAL FIRE DEPT I SHUT HER OFF AND PUT PLUGS, POINTS, CONDENSER, ROTOR,CAP AND WIRES ON , CHANGED OIL AND FILTER. STARTED HER UP AND APPEARS TO BE A BIG IMPROCEMENT BEFORE THE SMOKE BOMB WAS USED NOW I HAVE THE CARB OFF AND TOOK APART AND WANT TO CLEAN IT. THE CARB WOULD NOT ADJUST EITHER IDLE OR LOAD (STUCK) A LOCAL SHOP WILL DO THE BASKET THING OR I COULD GET THE CLEANER MYSELF. THE CARB HAS THE TAG WITH TSX-773 WITH 62 G UNDER THAT WHAT KIND IS IT? I'LL NEED A REBUILD KIT. FLOAT IS GOOD. THANKS AGAIN AND I'LL DRIVE IT OUT SIDE THE NEXT TIME I TRY TO LOOSEN RINGS ON AN OLD TRACTOR. D17JIM
D17JIM
10-29-2005 13:14:07
 Re: D17 CARB in reply to D17JIM, 10-29-2005 04:39:46
yes, its a marvel-schebler and i have kit and cleaner. tomorrow i'll put it together. AND ITS ALOT OF FUN EVEN IF I FIND MORE WRONG WITH IT. D17JIM
BCnT
10-29-2005 11:05:22
i run atf thru engines here when skeeters get too close ;)
sounds like you a few steps away from havin a runnin tractor.
have fun
cbp
10-29-2005 05:52:49
Now ya got me jealous. Sounds like you are having success and fun all in one. That would be a Marvel-Schebler if memory serves.
D17JIM
10-29-2005 04:41:41
FORGOT TO MENTION. CONCOCTION IN CYLINDERS SET 3 DAYS BEFORE STARTING.
