WD oils
Guyzoo
10-28-2005 06:48:02
What kind of oil goes in the front pedestal, differential/trans, trans clutch housing. Is 80w90 gear oil will be okay for the hand clutch
Sid
10-28-2005 09:59:45
 Re: WD oils in reply to Guyzoo, 10-28-2005 06:48:02
The only Lube that I am aware of for front pedestal is a grease zerk on the front of the tractor that is for the steering spindle shaft. The owners manual calls for SAE 80EP in the transmission,differentialand transmission clutch. Yes it will be OK for the clutch. A lot of differing opinions on this. This info comes from the owners manual Any other opinions on newer oils you will have to judge for ypourself.
