Allis
BonoGeo
10-27-2005 20:52:08
Can anyone tell me what year my tractor is,the casting number is U 3019-8,Thanks
cbp
10-28-2005 05:17:23
 Re: Allis in reply to BonoGeo, 10-27-2005 20:52:08
Look in the left column under "Research and Info". There is a Serial number list there. Most show where one would look.
I would guess that the casting number you posted would make this an older machine, maybe pre-40s prior to the AC common format of 6 digit numbers. That said, most will still have major component casting codes unrelated to the part numbers.
If that is a stamped 3019 and not cast, and the model is a U, it's a 1930.
Keith-OR
10-27-2005 21:45:03
 Allis serial number location in reply to BonoGeo, 10-27-2005 20:52:08
check this site out for your serial number and location for Allis tractors....Keith
Keith-OR
10-27-2005 21:24:12
Allis serial numbers are not cast numbers. They are stamped on the tractor at various different places depending on Model. Best is look at tractor photos listed on left side of this page under "Galleries".Once you detremine the model then someone could help you with the year!!..HTH Keith
