190 engin oil pressure
lonzo
10-27-2005 16:43:41
what is the oil pressure on a rebuilt 2900 engin suppose to be. what is the long spring with a valve that goes in the oil passage at rear of block for?
Gordon Chance
10-28-2005 18:37:39
 Re: 190 engin oil pressure in reply to lonzo, 10-27-2005 16:43:41
The long spring and plug in the back oil passage is there to block the flow of oil to the main oil gallery so that the oil coming from the filter has to go through the oil cooler before going to the main oil gallery. If you ever use one of the blocks from a turboed engine in a 180 or 185 with out the turbo, then you would have to remove the spring and plug in order to send oil to the main oil gallery.
Gordon
Joe(TX)
10-28-2005 18:26:35
The oil pressure is requlated a max 40 psi by the requlator in the side of the block near the injector pump. Mine only runs that high when cold.
Not sure about the spring thing.
