Engine Won't Start Allis C
Scott Gill
10-27-2005 08:24:43
My 1947 Allis C will not start at all.It was runnig good then srarted to pop,backfire and stall out.I found a cracked mag. cap and replaced it with a NOS cap now it won't start at all seem like no spark. Any ideas Thanks
Kent of SW MO
10-28-2005 06:11:54
 Re: Engine Won't Start Allis C in reply to Scott Gill, 10-27-2005 08:24:43
Which cap did you replace? The small that the plug wire go into or the one that covers the points. If you replaced the one that covers the point you need to time the bug and its drive gear.
Kent
Tom Davison, (PA)
10-27-2005 16:52:58
You stated that you replaced the mag cap. Check the brass rod on the cap with the rod on the cap that you removed. I had this happen to me on my B, the rod that came with the new cap was shorter and was not making contact with the coil.
old
10-27-2005 10:10:20
How do you know you don't have spark?? Did you pull one plug and hold it on the block and then crank the engine?? If you haven't done that your just guessing. You need to check for spark in that way first to make sure what your problem is. Then if you have spark you have carb problems, if you don't have spark then you need to maybe replace the points and condenser. If you have spark you need to pull the drain plug from the bottom of the carb and make sure your getting gas. If you aren't then you need to check the fuel lines/filters.
BCnT
10-27-2005 09:08:06
you mite replace points and condensor...if that doesnt fix it chances are coil went bad.
thot of 1 other thing...if your mag has a kill switch disconnect it at mag and see if it starts.
on the other hand same symptoms can be water in the gas and or plugged carb...try spraying some carb cleaner in carb while cranking just to make sure its not fuel related [works like ether but easier on engine]
