Looseness in Allis G Gear shift lever.
XXXXXXXXX
10-26-2005 18:32:48
Their is an excessive amount of side to side play in the gear shift lever in my Allis G tractor. How can I correct this? Thanks to all who reply.
IdaRed
10-29-2005 17:31:52
 Re: Looseness in Allis G Gear shift lever. in reply to XXXXXXXXX, 10-26-2005 18:32:48
9X I have a complete trans for a "G",. Let me know. Red Oct.29
Dick L
10-27-2005 10:16:04
If you are in neutral with a Allis G it will have a lot of movement from side to side because of the low low gear. If you put it into a gear that will move the tractor and you still have a lot of slop from side to side you may have a problem. If the later is the case I would guess that the problem would be found be removing the cover on the side of the transmission and checking the shifting fork assembly that is attached to the cover.
cbp
10-26-2005 19:58:34
Don't have a parts manual on that one and never owned one but if it were like it's peers I'd think it would be slop in the shift fork lugs themselves possibly. Does it go to it's full throw to the side to actually catch the gear?
