Here's my newbie showing. I bought a plow for my WD-45 to play in the dirt with. It's a Snap-Coupler style 3 bottom unit (I don't know the model number of the plow).I also bought a pair of Snap-Coupler lift arm latches and installed them. My problem is that the plow just barely clears the ground when I lift the arms up. Are the links on the plow just adjusted too long? I guess I would have thought that they would have been set at a correct length by whoever used it last - the plow has obviously been used. Could I have the lift arm latches installed wrong? When I put them on, I slid them onto the arms as far as they would go and then tightened the set screw against the body of the lift arms. Were the set screws supposed to go into the lift arm holes? I didn't do that because there wouldn't have been much meat holding the latches ontothe arms that way - they'd have just been flopping around on the ends of the arms. Thanks for your help. I'm new at this! Also, if anyone knows the model of this plow, I'd like to get a manual too, that tells me how to set it up correctly. Thanks!
