John...
BCnT
10-25-2005 11:26:32
read your diagnosis chart...think i found a typo...''2b) To insure the coils low voltage primary winding is not bad/open, use an ohmmeter and measure its DC resistance between its lil + and -terminals. If its an open circuit (no continuity) its bad/open and will NOT work. It should measure around 1.25 to 2 ohms or so if its a 6 volt coil and maybe 2.5 to 3.5 if its a 12 volt internally ballasted coil. NOTE CAUTION have all leads and any voltage source attached to the coil for this simple primary winding continuity test.''
in the CAUTION portion...shouldnt those leads be DISCONNECTED to test coil resistance?
chuck
retired fomoco electronic engine control specialist...fancy term for a grease monkey that knows what they replaced points n condensor with lol
John T
10-25-2005 11:36:51
 Re: John... in reply to BCnT, 10-25-2005 11:26:32
Oops, youre exactly correct, thanks, I meant to say (or mean) have any voltage DISCONNECTED lol or else it will mess up them cheap meters.
I will correct my standard posting
Im just glad someone actually reads n puts some thought into these postings
John T
BCnT
10-25-2005 11:46:36
 Re: John... in reply to John T, 10-25-2005 11:36:51
yep,i read em...i figger the day i know it all somebody will be diggin me a hole...plus i need my grey matter refreshed now n then ;)
thanx
chuck
