WD-45 Transmission Clutch
Phill Snartland
10-25-2005 11:19:58
I've recently finished restoring my WD-45, pretty much from the ground up, but I didn't have to go into the transmission for anything. Not long ago, I was trying to go very slowly forward to inch a load along by using the hand clutch and not the foot clutch. My reasoning was that I could slip the oil-bath wet-plate clutch without damage more than I could the dry plate clutch at the engine. What I found was that the movement was very jerky - I couldn't ease into moving very well.
Was this because the hand clutch probably hadn't been used for a very long time? Will it get better at slipping under load as I use it more? Or will it always be jerky like this?
Thanks for the info.
BCnT
10-25-2005 11:40:21
 Re: WD-45 Transmission Clutch in reply to Phill Snartland, 10-25-2005 11:19:58
did you change fluid in the Power Director? old oil can get sticky when it gets contaminated...i have a Series 1 D17 which i believe is the same as your WD45...manual calls for 8 qts of SAE 20 W 20 non detergent oil or i've heard some folks are using 20 weight hydraulic fluid in the PD
Phill Snartland
10-25-2005 11:43:44
 Re: WD-45 Transmission Clutch in reply to BCnT, 10-25-2005 11:40:21
In the WD-45, the hand clutch shares oil with the rest of the transmission. I did put new 80W-90 gear lube in the transmission when I put everything back together.
The D-17 and its Power Director must be arranged a little differently.
Thanks for your ideas!
BCnT
10-25-2005 11:54:13
 Re: WD-45 Transmission Clutch in reply to Phill Snartland, 10-25-2005 11:43:44
ok...sorry about that...guess the orange folks couldnt make up their minds on that one...i read in the later D17's they went to running PD in same sump with hydraulics.
i did just think of something tho...ford trucks have a problem with limited slip differentials ''chattering'' when using certain types of lubricants...parts houses sell an additive that works great...i wonder if it would help your tractor?
Phill Snartland
10-25-2005 11:55:40
 Re: WD-45 Transmission Clutch in reply to BCnT, 10-25-2005 11:54:13
That's an interesting idea. I'll check it out.
Thanks!
Kent of SW MO
10-26-2005 06:24:50
 Re: WD-45 Transmission Clutch in reply to Phill Snartland, 10-25-2005 11:55:40
I think if you will do futher checking the hand clutch should have 20 weight oil in it NOT 80W-90. If I remember right, It has been 30 year that I work at the Allis dealer, the only place 80W-90 was used was in the final driver and the front pedestal. The 80W-90 would make the clutch grab. Also most oil type clutches and brakes use a hydraulic type oil.
Kent
