The B is here - Yahoo!
mace56
10-24-2005 16:30:48
We'll a friendly gent from KY dropped off the new Allis B today. I could not wait to get home and see it. Just as the doctor ordered. Still in work clothes but that is Ok by me. All the tractors I remember never saw a wash hose or a paint brush in their life unless they were being auctioned off.
Oh well, here goes the 1000 questions...
I noticed a few things. No apparent connection from the generator to battery negative. I do see a wire across the front of the engine to the mag. Is that a kill button on the mag?
The right wheel rim is loose in the vee clamps to the casting. I have not figured out how to tighten yet. I ordered a book from YT. The Little Allis... I hope it helps show me a few basics. I will try to collect the original manuals over time.
Oh well, this is a long term project.
Thanks to all who sent replies to previous posts.
Texas Denny
10-24-2005 18:54:45
 Re: The B is here - Yahoo! in reply to mace56, 10-24-2005 16:30:48
The wheel rim and center have 4 clamps. Two of them have eccentric bolts which must be in the correct orientation to make the setup tight. The head of the stud has a mark on it to help in orientation. I recommend pulling one of the studs with the mark and examining it so you can see the AC plan for the wheel.
The generator should be hooked to a cutoff relay or to a regulator.
steve(ill)
10-24-2005 18:48:41
you need a book to get the drtails. basically it is a 6 volt positive ground system. Steve told you about the mag. the generator has a A and F terminals. A goes to the cutout, other side of cutout goes to ampmeter- then battery negative.--- the F terminal is the ground, but it goes thru the light swith to get there. has an inline resistor on the switch. if no switch, you can ground the F to test, but that makes it go to "full charge" which is about 8 amps.----- the rear wheels have 4 half moon clamps. two of them have bolts that are ecentric, or cam shaped. you loosen the nuts and turn the bolt heads and the cam action tightens the half moon aginst the wheel rim. Someitmes things get worn and you need to weld up the half moon segment where it touches the rim so it has more leverage. look at the bolt heads and you will see an arrow at the "high" spot.
Steve in N.J.
10-24-2005 17:56:49
mace,
Glad to hear your new child arrived! If she's equipped with a Fairbanks/Morse mag, the wire you see that attaches to it is probably from a mag kill switch up near the driver. There's probably a grounding lever on the mag also. On occasions you'll find that senario. As for the wiring at the gennie, we offer a complete wiring kit for your B if yer' interested. We also carry a complete line of electrical parts and services too. Drop us a line if you would like to know more about it. Good luck with your "new-comer". As I mentioned before, they're a nice little machine and can do a whole lot of work for ya! I use my B almost every day....
Steve@B&B
