WD Rebuild Kit
TnFarmer_AC
10-24-2005 11:44:44
I finally decided to get my 1953 WD (SN WD146157) up and running again. The only place locally I know of that can obtain AC tractor overhaul kits is NAPA. They tell me the only kits available thru them are for WCs and WD45s, no WD source available. There was no explanation but I don't think the woman behind the counter really cared why.
I know I can order off the internet but I really wanted to order through a local business.
Would a 45 overhaul kit (pistons, sleeves, gaskets, rod/main bearings, etc) work for a WD?
Red Kap IL
10-25-2005 08:27:04
 Re: WD Rebuild Kit in reply to TnFarmer_AC, 10-24-2005 11:44:44
I bought an engine rebuild kit from the shop that refurbished the engine head on my WD45. You might check with a local machine shop.
gene (missouri)
10-24-2005 22:48:01
Try your other local autoparts stores. They can get overhaul kits - depending on how incompetent the people behind the parts counter.
If you want knowledgeable people try the advertisers on this web site.
Gene
Jerry Coulter
10-24-2005 17:07:05
WC and WD engines take the same parts, except the WD has a stiffer governor spring which makes the engine run faster. If you use WD45 parts, you have to change the crankshaft, too.
old
10-24-2005 14:50:12
I maybe wrong but I think the kits for the WC and WD are the same. And by what I see in my value bitl catalog they are depending on the serial numbers that is. Drop me an e-mail and I'll give you value bitls phone number since I can't post it here.
ricedaddy
12-06-2005 17:26:40
 Re: WD Rebuild Kit in reply to old, 10-24-2005 14:50:12
They ARE NOT the same
