Mod C fan pulley
tz50
10-24-2005 10:41:58
The fan pulley width is adjustable. There are 2 studs (or bolts) that are used to secure the forward sleeve of the pulley to the pulley body at the desired width. One of the threaded studs (or bolt) is stripped. How is the pulley attached (secured) to the shaft? The objective is to remove the pulley assembly and replace the stripped stud (or bolt). Thank you.
Jerry Coulter
10-24-2005 17:03:02
 Re: Mod C fan pulley in reply to tz50, 10-24-2005 10:41:58
Remove the 4 bolts that hold the fan blade on, then the pulley assembly comes off, too.
