WD 45 gear shift
Bill 45
10-24-2005 05:14:45
The gear shift on the WD45 ihas a great deal of play in it when tryin to shift. Is this something that is easy to repair?
Brian G. NY
10-24-2005 05:58:17
 Re: WD 45 gear shift in reply to Bill 45, 10-24-2005 05:14:45
I got mine to work better by drilling out the tower "pin" holes to 5/16" and fabricating new pins from a couple of 5/16" Gr 5 bolts. Secondly, I built up the shifter lever end and reqround it to the shape I estimated to have originally been. Both of these take patience as they are "grind and fit" operations. I believe both the new pins and shifter levers may still be available from Agco.
bill 45
10-24-2005 07:34:07
 Re: WD 45 gear shift in reply to Brian G. NY, 10-24-2005 05:58:17
Thanks
jdo
10-27-2005 01:45:49
 Re: WD 45 gear shift in reply to bill 45, 10-24-2005 07:34:07
dealers sell oversized pins for the shift lever. I recently purchased a set for under ten bucks. Idrilled the hole in side of housing using a 9/32 bit. I then had to file the sides of the groove in shift leverso the top of pins would fit in. It took anout an hour and took a lot of the slop out of the shifter.
