C Allis Engine Rebuild
Danofarming
10-23-2005 19:26:01
I want to buid my engine to a D-14 Engine. What all will I have to change besides the crankshaft?
Dick L
10-24-2005 07:40:23
 Yup, You Can! in reply to Danofarming, 10-23-2005 19:26:01
I put the D-14/15 over bore kit in my C. All it takes in money and a good machine shop that don"t tell you that you shouldnt do it. The OD of the sleeve flanges of D-14 are the same as the C. You will have to bore the C block to the diameter of the D-14 sleeve. You will have to email me for the exact information.
Texas Denny
10-23-2005 21:02:56
 Re: C Allis Engine Rebuild in reply to Danofarming, 10-23-2005 19:26:01
While the block is the same, the conversion will not be easy. The D-14 has a 0.500" larger bore and a 0.3875" longer stroke. I could calculate it (or you could as well), but without calculating, I don't know if the extra bore and stroke would be enough to increase the compression ratio from 5.75:1 to 7.5:1. At any rate, I don't think the C block will accept more than sleeves with an 1/8" larger bore. To get in bigger sleeves than that, you'd need to re-machine the block.
Great idea though. If you have any success, I for one would sure be interested. Hope someone else can shed some light.
