Allis B Final Drive
Larry in Centra
10-23-2005 16:58:37
If you remove the final drive on an Allis B, is there a gasket on this joint, or is it metal to metal? I'm assuming it's gasketed, but I don't have a clue where to buy the gaskets, 'cause I've never seen them. Is this a gasket that you have to make, or is there a good source?
Thanks for the help.
steve(ill)
10-23-2005 18:46:53
 Re: Allis B Final Drive in reply to Larry in Central Wisconsi, 10-23-2005 16:58:37
there is no gasket. you take off the 4 large nuts, and slide the case off. the axle is splined and it slides thru an oil seal into the bevel gear set. The seal keeps the transmission/ bevel gear oil inside. The final drive case has a seal inside it that keeps the gear lube from coming out the top shaft. the area between the seals is supposed to be dry, that is the bolted join.
Larry in Central WI
10-23-2005 19:54:33
 Re: Allis B Final Drive in reply to steve(ill), 10-23-2005 18:46:53
Thank you for the insite, Steve. It sure helps knowing what your getting in to. I appreciate the help.
