AC B gear shift rubber boot
Robert in Md
10-20-2005 18:52:35
Where can I buy a new rubber gear shift boot for a AC B.? The old one is rotten and leaking water into the transmission. Thank you.
souNdguy
10-22-2005 21:52:57
 Re: AC B gear shift rubber boot in reply to Robert in Md, 10-20-2005 18:52:35
I ended up using a cvaxle boot from a small import car.. got it at carquest for 5$.. fit perfect.. no leaks.. looks nice.
Soundguy
Mike(MA)
10-21-2005 15:33:37
When you select a vendor, they may ask you if you want the original style or the newer style. The original style had 2 or 3 ribs and was shorter but tended to leak rain a bit. The newer style looks more like a shock boot from a truck but is supposedly less prone to leakage.
Mike
chalmersbob
10-20-2005 19:09:20
CHECK SUPPLIERS ON THIS SITE, OR local agco dealer, or other tractor supply. also on ebay. BOB
