Identity?
Ken Jansen
07-25-1999 10:01:10
Trying to identify a tractor. I have been told that year is a 52. I do not know the exact model. Looks like a wd or wd45. Where is the serial number and where can I have that crossed to a model and year. It is a tricicle.
Brian Goodfellow
07-25-1999 11:36:27
 Re: Identity? in reply to Ken Jansen, 07-25-1999 10:01:10
Sorry, I meant to credit "chuckie", not you for where to get the serial # info. Brian G.
chuckie
07-25-1999 10:26:30
the number watt you are looking for is stamped in just ahead of the gear shift lever. and then you can find watt u got by looking to the colume to our left
Brian Goodfellow
07-25-1999 11:33:27
 Re: Re: Identity? in reply to chuckie, 07-25-1999 10:26:30
Actually, the serial number on a WD or WD-45 is located on a smooth surface just above the left hand brake adjusting screw and below the brake spring hole on the differential housing. Use a sharp putty knife, gasket scraper or similar tool to scrape away the paint and any accumulated crud. The serial # will be prefixed "WD" with 5 or 6 numerals. Beginning with serial number 146607 (in 1953) tractors were WD-45s. Prior serial numbers indicate a WD. Hope this helps.`As Ken Jansen said, click on "Tractor Shed" on the list to the left of your screen and you'll find serial numbers which will let you determine the actual year of manufacture of your tractor. Brian G.
