Trouble with my allis chalmers D-12
Fred
07-25-1999 09:31:22
my tractor will run fine for about 30 to 40 min and then starts to cut out but it does not die.It sounds like it is starving for gas. the gas tank has been repaired and the settling bulb is at an angle. if there is anyone that can give me any insight I would be greatly appreciative. thanks
Dannyj
04-08-2001 14:52:43
 Re: trouble with my allis chalmers D-12 in reply to Fred, 07-25-1999 09:31:22
When my D-12 did that a new coil solved the problem.
Jackson
07-27-1999 12:06:11
fred,you could be getting air in the fuel line as the gasoline gets warmer.try to get the setiment bulb straight down,that might solve your problem.good luck...
Jackson
07-27-1999 12:04:23
