Timing marks on Allis Chalmers G model
Don Retzlaff
10-19-2005 19:51:28
I know the timing marks are on the crankshaft pulley end of the engine. Could somebody who knows, tell me what I am looking for. I see no notches or other type reference points for timing. Need help on this one. Thank you, Don Retzlaff
Plant Doctor
10-20-2005 05:11:37
 Re: Timing marks on Allis Chalmers G model in reply to Don Retzlaff, 10-19-2005 19:51:28
Don: The ignition timing mark on the face of the crankshaft pulley is viewed through an inspection port hole located directly under the hole where you would hand crank the motor. The mark should be at the 6 o'clock position when #1 spark occurs.
Joe M(GA)
10-20-2005 03:19:20
Small line in pulley, to be viewed through the hand crank hole
Don Retzlaff
10-20-2005 08:22:45
 Re: Timing marks on Allis Chalmers G model in reply to Joe M(GA), 10-20-2005 03:19:20
Thanks Joe, With your help and scraping off multiple coats of Persian Orange, I found the line. Simple huh when one knows where and what to look for. Thanks again, Don Retzlaff I live in Upper Marlboro, Maryland, have a little bit of this and a little bit of that, need help, let me know.
