WD front
lpaz
10-19-2005 13:25:11
I recently purchased a WD that I intened to use as a parts tractor for my other WD. The parts WD has a wide front end, and my other WD has the narrow front end. I would like to switch the wide front end on the parts tractor to my other WD. I was just wondering if there any "gotchas" to avoid, or what is the best way to take out the front end?
Where is the best place to support the tractor when the front end comes off?
Texas Denny
10-19-2005 19:02:10
 Re: WD front in reply to lpaz, 10-19-2005 13:25:11
When I did this, I removed and loosened all bolts on one entire side all the way to the differential. And I needed a hydraulic jack to break the side rails loose. Not too difficult if no bolts break - seven of mine did. Put some penetrant on there days in advance.
JMS/MN
10-19-2005 15:27:48
Support the tractors in the middle- the castings, rather than the oil pan. About 8 bolts and a steering shaft pin to take out. Helps if you loosen some side frame bolts and pop the rails loose with a wonderbar, etc. Also likely to need to loosen the front engine support angle iron from the side rails.
lpaz
10-20-2005 09:44:27
 Re: WD front in reply to JMS/MN, 10-19-2005 15:27:48
Thanks for the information. I'll start dousing the bolts on the frame rail with some penetrant stuff, and hopefully ZI can get around to this in a couple of weeks or so, before the weather starts turning cold here.
