WD-45
KMichael
10-19-2005 11:30:30
I recently purchased a 1956 Allis Chalmers WD-45 Wide front gas tractor. My question is, there is a handle to the left of the shift lever that comes up and turns to the right in front of the shifter. It has a cable hooked to it so when you pull back on the lever it pulls the cable upward. Can anyone tell me what this control is for, what it does?
I am new to owning a tractor, and the only one i have been around is a farmall cub.
thanks, Ken
acowner
10-19-2005 11:59:49
 Re: WD-45 in reply to KMichael, 10-19-2005 11:30:30
What you are referring to is Snap-Coupler lever for attaching and detaching Allis Chalmers implements and the standard drawbar. If you look under the tractor at the front of the drawbar you should be able to see the the hook that holds them. The lever is up top so that the operator could easily attach AC implements by use of the lever.
BCnT
10-19-2005 13:06:14
 Re: WD-45 in reply to acowner, 10-19-2005 11:59:49
i painted the lever on mine red so i wouldnt touch it...found out what it was first time i used my d17 to shred with...pulled lever thinking it was PTO and drove off dragging pto shaft...left shredder and towbar layin there :::shakin head:::
mace56
10-19-2005 17:56:48
 Re: WD-45 in reply to BCnT, 10-19-2005 13:06:14
I think I remember the D series drawbars had two pull pins in the upper connection as well as the snap coupler latch. Or did that only hold the guide slot in place? Was the actual drawbar only held on by the coupler?
I pulled a lot of hay wagons with a WD and never even thought about the coupler jaw popping loose.
BCnT
10-19-2005 19:00:41
 Re: WD-45 in reply to mace56, 10-19-2005 17:56:48
this drawbar aint stock...its cobbled together from oil field junk and yes...bottom coupler is all that holds it on...it slides thru the brace that attaches to snap couplers
