WC 1934
Ian Jemmett
10-19-2005 11:11:14
We have a Allis Chalmers WC Unstyled 1934 in need of a few parts. The tractor is in Mildenhall Suffolk England.The number on back axle is WC 963 The number on front axle AM 2665 SU
The back axle has 6 studs with 27inch x10inch rims
The front has 5 studs with 17 1/2inch x5 1/4 rims.
Could anyone tell me if these are the right rims for this model and year?
Texas Denny
10-19-2005 12:17:45
 Re: WC 1934 in reply to Ian Jemmett, 10-19-2005 11:11:14
My book says yours is a 1933 WC - actually one of the first 1000 built. My Nebraska test is for the 1938 version which still is unstyled like yours. But the test was run on 12X24 tires on rear and 5.50x16 on the front.
Allis had two rim versions of 10" wide x 28 and I think 11" wide x 24. Noone had ever to my knowledge made a 27" tire so my guess is your rim is 10" wide x 28" diameter. I'd suspect your tire size is 11 x 28 or 10 x 28. I'd go by the current tire size when getting new ones. The tread style used in 1934 is not available - as far as I know.
The front rim should be 5" wide x 16. Are you measuring from the base of the bead flange on one side to the opposite base of the bead flange? This would be the way to measure both front and rear rims. I usually measure inside of the wheel and add 1/4 to 3/8 for the rim thickness. Very hard to get this measurement exact.
