serial number
Dave Parker
10-19-2005 10:55:34
where do i find the serial number on a d-17 allis chalmers?
JMS/MN
10-19-2005 11:09:54
 Re: serial number in reply to Dave Parker, 10-19-2005 10:55:34
Left side, front end of the torque tube- the casting that the engine bolts in to. Number you find on an engine is an engine serial number. Just rearwrd of the carb. Tube has the tractor serial number, and will start with D17. Serial numbers are STAMPED- not cast into a part.
BCnT
10-19-2005 11:09:18
on my '59 its on clutch pedal side on the bell housing...AC calls it a torque tube...you prob gonna have to scrape some paint to find it...its on the slanted flat part thats right behind engine block
Dave Parker
10-19-2005 12:49:35
 Re: serial number/brakes in reply to BCnT, 10-19-2005 11:09:18
can a brake be installed with out removing the axle housing? thanks for the info on the ser. no. right where you said.
JMS/MN
10-19-2005 15:33:12
 Re: serial number/brakes in reply to Dave Parker, 10-19-2005 12:49:35
Check a parts book after you find the serial number. Won't swear to this, but maybe Series one had band (only) brakes like a WD45, but the series 3 has different setup - band and disc?. Anyway, it has a band and another portion with balls that run in a tapered track- like the F2 combine. Series 3 you need to pull the axles out.
BCnT
10-19-2005 13:10:33
from what i understand they can be...i havent had the pleasure YET but from what i read here sometimes its easier to get bottom pin out if you loosen backing plate...either that or use dynamite
