AC disc
Shadow
10-16-2005 18:27:54
I have an old disc that I would like to convert to a snap coupler disc for a WD. I cannot find a picture of a snap coupler disc and was wondering if someone out there may be able to send me a photo of one. I would like to look at the photo while I am trying to convert this old one. Thanks!
Mike
chrispratt
10-17-2005 19:54:12
 Re: AC disc in reply to Shadow, 10-16-2005 18:27:54
I have the 7 foot. There are a lot of weeds around it just now but I'll see what I can do. May take a couple of days but if you're still interested, I can get the measurements.
The lifts are easy since they are just chains with center and rod assembly that would be easy to weld. I did the same with a cultivator set. The tongue may not be so easy because the loop has to be pretty well made and if you heat and bend rod, it's not going to last as well as it will tend to wear at the front.
I went opposite direction on the spare disc I had, and it worked great as a three point unit (in fact I think I even ended up with an extra loop from that).
Texas Denny
10-16-2005 18:50:51
Are you trying to do a wheel disk or fully mounted?
