Great article Denny, thanks for finding n posting it. Now ya got me curious to dig out the one I have somewhere?? Geeeee e this is almost getting to be work lol but its funnnnn work for me at least. Sorry if we bore others, we can take this good discussion to e mail if need be? Ive just read it quickly and already agreed with it about the advantages of a solid state switch to provide a faster and more positive current interruption versus the bouncing ringing mechanical contact points. Better switching improves the inductive transfer cuz as we well know ther is NOOOOO O transformer action at DC. (need the di/dt you spoke of) An elec switch would make even the stock coil function more efficient (less heat and more electrical transfer) but couple them with the newer high energy high efficient coils (better magnetic materials etc) and then run that wider plug gap (those coils are capable of ramping to higher voltaes) and performance gets even better..... I didnt see too much about what I still dont know about some older 12 volt coils having a pure non inductive resistor in the top portion. Im almost positive (I think Duane Larson spoke of that over on JD board a good while back) some older ones had like a ring about an inch down where I been told?? there was an internal ballast, but am quite confident the later ones either used more wire (more turns and/or inductance/henrys) or just wire with higher resistance??? So where are we now lol. I think??? we all agreed on these things::::::: They still run 4 amps REGARDLESS if a 6 or 12 volt coil,,,,, ,,an autotransformer (the coil) inductor is a "current device" and its the current interrupted NOT the voltage that does the work and matters,,,,, ,,,and the firing voltage remains the same (its a function of the plugs gap n compression),,,,, ,,,,,and the article makes sense too much plug gap curent isnt good (burns plugs),,,,, I AGREED AT LEAST IFFFFF F the 12 had a pure internal ballast INSTEAD OF more windings or inductance,,,,,the the 2 coils are equivalent BUT I DID NOT AND STILL DONT AGREE they are equivalent if the 12 has more windings or inductance, as I think if so there may a more efficient transfer and more energy transferred to the seconday VERSUS wasting the energy as pure heat. STILL UNKNOWNS What are the inductance in henrys of the primary windings in comparable 6 or 12 volt coils????? ?? Does a 12 volt have more wire or turns or the same as a 6 but higher resistance wire??? I guess my intuition still keeps me believing the 12 volt (if NOT one with a top pure resistor, i.e. more turns and/or inductance) is still more efficient and wastes less energy on heat as oposed to transfering it the seconday VERSUS a 6 volt??? True, the article talks like once theres sufficient spark to ignite the fuel, thers no more needed, but I dont see it saying the 12 volt coil "may not be capable of" providing maybe MORE energy (would be manifested as more arc current since voltage is the same) which might?? better initiate the combustion UNTIL we get to the point of too much and wasted current to prematurely burn up the plugs??? I still believe the ballast to be older technology and it gives me "heartburn" lol as I know its by product is pure heat versus the by product of inductance which leads to mutual inductance and energy transfer from primary to secondary and the plug where it can ignite the fuel VERSUS transfer heat to the surroundings. Im NOT from Missouri but still stibborn lol I guess the only way to ever know the answer is to have sophisticated equipment to accurately measure the energy (volts x amps x time) across a plug gap when using a 6 volt with external ballasted coil versus a 12 volt NON ballasted coil. I stilllll ll would bet the 12 volt causes MORE energy to discharge at the plug gap !!!! We know darn sure the 6 with an external ballast expends considerable heat energy across itself!! Isnt Bob gonna do that for us????? ????? Thanks again Denny, loveeeee ee this stuff I apologize to others who dont like it as much and discussing it like we do, if Kim pulls it we will take it to e mail lol G Night all n God Bless yall n the good ol USA If I dig out the article on Kettering Ignition I will try n post it too John T
