head differences?
bob in Wi
10-16-2005 05:27:50
I need to replace my d-17 head and need to know the differences in the two different castings. The head that was on it was a wd-45 head. I've been told that a late IV to 175 had frost plugs and all 1/2" and not a combination of 1/2" and 3/8" head bolts. Also will the late one work on a early 57 -59 D-17?
Texas Denny
10-16-2005 06:59:56
 Re: head differences? in reply to bob in Wi, 10-16-2005 05:27:50
Bob, do you have the head removed? If you do, you'll notice that the head is flat with little or no combustion chamber. The change in compression ratio from 6.45 to 7.5 had to be done by pistion design as the crank stroke was not changed. If I'm right, a newer head will not change anything.
