allis b stalling out
tim coltman
10-15-2005 08:02:24
hi my little allis b is having some problems and im stumped. okay when its running doesnt matter if idle or full throttle for 10 min approx. the engine all the sudden will sound like its working real hard and within 10 seconds die. it will start right back up with no problem but in about 10 min will die again. it is getting gas. i checked that not sure what else to check. thanks for any help tim coltman
old
10-15-2005 08:44:10
 Re: allis b stalling out in reply to tim coltman, 10-15-2005 08:02:24
10 minutes sounds like a fuel problem. Probably have a clog in the tank or line. If it was a coil or condenser problem it would not start right back up but a restriction in the fuel system would do that. I'd guess that theres some junk it the tank or in the line. Also in a lot of carbs theres a filter in the brass elbow where the fuel line hooks to the carb and it maybe clogged
BCnT
10-15-2005 08:33:51
is there any rubber hose in your fuel line? i've seen hose crack internally and a flap of rubber will fold over like a check valve and stop an engine.
could be electrical too...coil or condensor heating up and breaking down
tim coltman
10-15-2005 08:52:20
 Re: allis b stalling out in reply to BCnT, 10-15-2005 08:33:51
its not the fuel im positive of that and it has a magneto that has been rebuild has less than an hour on it. tim
old
10-15-2005 10:27:50
 Re: allis b stalling out in reply to tim coltman, 10-15-2005 08:52:20
Don't discount it being a fuel problem. Did you remove the gas tank and clean it?? If you didn't you probably have some floating junk that stops up the line when its running.
BCnT
10-15-2005 09:21:06
did the problem start before or after you had mag rebuilt? i cant tell you how many times i've gotten brand new parts that were bad
tim coltman
10-15-2005 09:31:21
 Re: allis b stalling out in reply to BCnT, 10-15-2005 09:21:06
i bought it not running so i dont know.
tim coltman
10-15-2005 11:29:32
 Re: allis b stalling out in reply to tim coltman, 10-15-2005 09:31:21
the tank is shiny clean, brand new fuel line, and i rebuilt the carb so i know that is not the problem plus if it was the fuel it woudnt start right up it would take a few min for fuel to drain back down and fill the carb.
tim coltman
10-15-2005 11:27:02
BCnT
10-15-2005 13:02:28
 Re: allis b stalling out in reply to tim coltman, 10-15-2005 11:27:02
must be possessed then...any exorcists in tha house?
