best head torque ft. lbs. for AC-WD
ron bond
10-15-2005 07:41:00
I have just replaced the head gasket (it blew through between cyl's 2 and 3) and had a valve job done on me WD. The ITT says 25# on the small head bolts and 70# on the larger. Anyone disagree with this and have a better torque ft. lb.?
thanks-ron
Gordon Chance
10-15-2005 19:34:04
 Re: best head torque ft. lbs. for AC-WD in reply to ron bond, 10-15-2005 07:41:00
I started working at an A-C dealership in 1976 and the head bolt torque for the 1/2" bolts has always been 90 Ft. LBS in all of the A-C manuals that I have seen and used. I don't know where I&T came up with 70 Ft. LBS, but it is not right. You might torque the bolts to 70 and get by with it but it is not the correct torque spec. for this engine. 25 Ft. LBS for the 3/8" studs is correct.
Gordon
Texas Denny
10-15-2005 18:45:57
Those are the numbers that I use. When it is hot, you're supposed to pull the valve train and re-torque.
