cranks
olie
10-14-2005 14:35:41
Hear a lot of talk around the club about this fellow who put a wd-45 crank in his wc. Looked up some information on this, The only thig diff is the stroke 4.0-4.5. Besides the crank what else do you need from a wd-45 and what wc parts do you use.
Thanks OLie
Tramway Guy
10-14-2005 20:34:42
 Re: cranks in reply to olie, 10-14-2005 14:35:41
It might work if the original pistons had low-compression [kerosene/distillate] pistons to start with.
wdtom
10-14-2005 17:31:54
I think the only other thing you need is the 45 pistons. The extra stroke is compensated for in the piston. using 4" stroke pistons with a 4.5" stroke crank will have the piston going up 1/4" too high.
