Allis 190XT
Michelle Kowalc
10-14-2005 08:38:21
Help! The cows pulled all the spark plug wires off the tractor distributor. Does anyone have a diagram as to which distributor ports go to which plugs? The wire lenghts do not help as they pulled and lost some of the wires. Would like to take care of this before my hubby gets home and flips..... .
Joe(TX)
10-15-2005 17:25:45
 Re: Allis 190XT in reply to Michelle Kowalczyk, 10-14-2005 08:38:21
1-5-3-6-2-4
JMS/MN
10-15-2005 08:04:26
I was going to answer this for a WD45, but just noticed the tractor is a 190XT- 6 cylinder engine. I don't have a book, but check if the firing order is cast into the block, or distributor drive- like on a WD it's 1-2-4-3. If the distributor sits vertical, #1 is likely to be to the front side of the tractor, and you number them clockwise. Hook up the wires in order, and if it doesn't start, try advancing or retarding them one hole. The operator manual should have the firing order if it is not on the block.
Gatz
10-14-2005 16:22:53
I'd line up every one of those cantankerous bovines and grill 'em like a Drill Sergeant 'till ya get the answer!!
