Heyyyyy yyyy, You rascal, youre not posed to answer a question with another question lol. Energy is harder to compute then the voltage or current cuz its like what we buy from the utility which is Volts x Amps x Time i.e. Killowatt Hours. The energy the coil expends in the form of Volts x Amps x Arc Time duration across the plugs gap is what gets stored in the primary when the points are closed and shes conducting current LESSSSS SSSSS SSSSS SSSS heat and transfer/coupling losses PERIOD regardless if in a 6 or 12 volt coil. BUTTTTT TTTTT TTTTT the 12 volt coil has more windings or just more wire AND I SAY PROBABLY MORE INDUCTANCE AND MORE HENRYS then the 6 volt (has to have something else, cuz its twice the ohms unless it has that pure top resistor only portion) THEREFORE I stand on it has more energy storage capacity (cuz more inductive windings, more Henrys) and is capable of expending more energy across the plugs gap PERIOD..... ..... . We know the coils firing voltage is the same, so I say with a coil of more inductance and more energy being pumped into it and more storage potential, its just gotta dump more amps (results in heat) across the plugs gap or the same amps over more time. Only Einstein and all that atomic energy and splitting the atom stuff might defeat one of the laws of physics that energy cant be created or destroyed, only changed in form Sooooo oo the 12 volt coil has more energy being pumped in (I squared R),,,,, ,,,,, and if it has more coil n wire it has more Inductance in Henrys,,,,, ,,,,,and it can store more energy,,,,, ,,,,, THEN IT CAN TRANSFER AND EXPEND THAT MOREEEEE EEEEE ENERGY ACROSS THE PLUGS GAP EUREKA !!!!! !!!!! !!!!! ALSO I agree with you that much of the coils energy gets wasted as heat versus spark gap, HOWEVER the 12 volt coil still has more energy being pumped in to be stored and more which can transferred my mutual inductance over to the secondary to get expended across the plug SO GOSH DARN IT it should still be more then with a 6 volt coil REGARDLESS how much heat is wasted in either. You ask abuut the plugs energy, to know that one would have to measure the arcing current flow ascoss its gap,,,,, ,, and at what voltage the arc was initiated,,,,, ,,and how long how much curent flowed to get Volts x Amps x Time BUT thats one heck of a hard thing to figure out and compute, I sure dont have the equipmemnt to do it. WE KNOW FOR DARN SURE any energy wasted in that ballast IS PURE HEAT and Id rather expend my energy in an inductive coil of wire where its stored in a magnetic field and has the potential of getting transferred over into the secondary then the plug gap THEN LETTING IT HEAT UP THE BALLAST which stores ZERO energy. I reckon we can respectfully agree to disagree but in the meantime know what Im gonna do????? ??? Im gonna run right out to my D 15 and throw that ballast away and install a full 12 volt coil AND I BET IT RUNS BETTER !!!!! !!!! I bet SoundGuy n maybe Bob will agree with me???? Thanka a bunch Denny, I really enjoy n appreciate your inputs n this discussion. John T
