wd 45 head torque and valve lash?
steinbacher
10-13-2005 08:24:09
need to know these for reassembly of a freinds tractor. thank you
Kevin (FL)
10-13-2005 10:58:20
 Re: wd 45 head torque and valve lash? in reply to steinbacher, 10-13-2005 08:24:09
Cylinder head nuts: 95-100 ft-#'s (That's listed for a diesel model in my I&T manual.)
Later in the gas section under cylinder head it says to torque the 1/2" studs to 70 ft-#'s and any 3/8" studs to 25 ft-#'s.
Valve lash (diesel)intake: .010" hot exhaust: .019" hot
Gas engine intake or exhaust: .012" hot
Gordon Chance
10-15-2005 20:06:08
 Re: wd 45 head torque and valve lash? in reply to Kevin (FL), 10-13-2005 10:58:20
I don't know how I&T came up with 70 Ft. LBS on the 1/2" bolts for the gas engine, but every A-C service manual that I have seen and used since 1976 has called for 90 Ft. LBS for the 1/2" bolts.
Gordon
steinbacher
10-14-2005 04:44:35
thank u kevin
