Hey Denny, thanks again for all the help you provided me on my AC D 17. Im e mailing you with another hydraulics question, my manuals and new seat cushions may arrive today. Regarding this current topic of discussion, I have a few thoughts/questions regarding the choice/benefit of EITHER the full 12 volt rated coil VERSUS using a 6 volt coil and a series ballast. Youre an ex engineer also right?? I LOVE these deep technical discussions, here goes, hope we dont bore the others. Lets look at it in terms of ENERGY. Except for the inefficiencies and heat losses (a coils not a 100% perfect transfer device as we all know) the coils output energy, much of which eventually gets expended across the spark plug gap, corresponds to what energy enters it and can get stored when the points are closed and shes conducting current. Okay, if its a 12 volt coil and shes drawing 4 amps (typical) thats 48 watts of instataneous power input, while the output, of course, is less due to heat and inefficiency losses. HOWEVER, if its a 6 volt coil (regardless if after a ballast or on a straight 6 volt tractor) and it, likewise draws 4 amps (still typical) thats only 24 watts of input power, correct??? THEREFORE, MY QUESTION FOR DISCUSSION IS Wouldnt the energy stored in a 6 volt coil when its conducting current, and what eventually gets expended across the plug gap, be LESS THAN the energy stored and expended in a full 12 volt coil????? ????? ????? HOWEVER AGAIN:::::: I believe (not dead sure on this) some 12 volt coils are "internally ballasted", meaning they have an internal pure non inductive/coil resistance and, therefore, the energy they store in their magnetic field and which gets expended across the plugs gap would be near the same as on a 6 volt coil. As I understand it, the max curent the points can switch, and still last a reasonable time, is around 4 amps or so. Thats why a 6 volt coils primary resistance (measured between its lil + and - terminals) is only about half that of a 12 volt coil. That way, regardless of voltage and coil (so long as correct) the points still switch around 4 amps AND ITS THE POINTS CURRENT SWITCHING CAPACITY thats the limiting and design requirement factor. Sooooo oooo QUESTION/DISCUSSION for yall, wouldnt you store more energy (and expend across the plug gap) when using a 12 volt coil then in a 6 volt coil????? ????? ????? ????? ????? ????? ????? ????? ????? ????? ????? ????? ????? ????? ???? I TOTALLY AGREE the 6 volt coil + ballast is pefectly acceptable (still whats on my D 15 lol) and works fine, I just wonder if one wouldnt store and impart more energy across the plug gap when using a 12 volt coil PROVIDED THE 12 VOLT COIL ISNT INTERNALLY STRAIGHT DC RESISTIVE BALLASTED !!!!! !!!!! !!!! i.e. if it has BOTH coil/transformer windings PLUS some straight NON INDUCTIVE resistor/ballast portion. Im just unsure if all its resistance is part of the actual coil/wire windings or if it has an internal pure resistive portion. Seems like some have a separate top portion where its ballast instead of coils, anyone know fer sure????? ??? ONE MORE THING The energy expended across the plug gap is NOT just volts x amps, but volts x amps x time. The firing voltage is a function of the plug gap and the medium (compresion and fuel), so for the same current, to expend more energy, that would just mean a longer arc duration. BUTTTTT TT what is it that ignites the fuel more efficiently n completely??? Is it the raw sudden release of "heat" (caused by current arc gap) or does it ignite better if the current arc is of less amperage (which would cause less heat) but lasts a longer time????? ? Still looks to me regardless, a 12 volt coil has more energy to expend then a 6 volt would????? ? What ya think Denny and others??? Any good hearted cussin or discussin lol John T
