The Way I Check From There
Dick L
10-12-2005 18:27:55
If the timing gears are all at the correct place. I take all the plugs out, put a plug on number one plug wire, ground the plug base to the block, hand crank very slowly( inching the crank) until I hear the snap and see the spark on number one. Walk around to the other side and make sure that TDC is in the center of the inspection hole.
It should be! If it is not it should be you task to get it there. The advance is mechanical and if started in the described position it will show the FIRE line to a timing light.
