ALLIS CHALMER WD45
RICHARD UNDERWO
07-23-1999 19:21:47
My 3 point hitch arms keep rising and lowering. What should I replace in the hydraulic valve system. The hydraulic pump works. It just doesn't hold. Gotta get this working quick...hay on the ground!
bill
03-01-2000 21:34:48
 Re: ALLIS CHALMER WD45 in reply to RICHARD UNDERWOOD, 07-23-1999 19:21:47
dont remember what is called but harry fergeson pioneered it to lift and put more down pressue on rear wheels all tractors later adapted some version of this but anyhow thats where your problem lies .
Gordon Chance
07-23-1999 20:11:46
Richard: Check to see if the two plates on the hold position valve on top of the pump are locked together. If they are not and the screw is locked into the body of the valve, then it is set for traction boost and the check ball is held off of its seat. Screw the locking screw out of the body and into the control plate to lock them together and you should be able to get your arms to hold where you set them. I hope that this helps.
Gordon
